Pritunl v1.30.3333.72 and Pritunl Client v1.3.3329.81 has been released. This update adds a new connection single sign-on authentication option. An IP pool issue that caused the dynamic address pool for multi-device connections to run out has also been fixed.
Single sign-on connection authentication
Single sign-on connection authentication provides a new way to add additional authentication to each VPN connection. In addition to the current profile certificate and single sign-on API checks. This option will require the user to complete a single sign-on authentication from the web browser for each VPN connection. Authentication cache can be enabled to reduce the frequency of this.
When a user attempts to connect to a server with single sign-on authentication enabled a web browser will open. This will prompt them to complete authentication with the single sign-on provider and once complete the VPN connection will authenticate. If a system default web browser isn’t configured a link can be copied from the prompt. More information on configuring this feature can be found in the single sign-on connection authentication documentation.
Disable default gateway option
An option to override the routing of internet traffic on a VPN profile that is configured to route internet traffic has been added. This option can be found in the profile settings on the latest client release.
