Dear @zach ,
I finally managed to setup my Pritunl VPN-Servers.
I would love to use Pritunl VPN-Client in a small (minimal) Alpine Linux LXC-Container on my Proxmox-Homeserver.
Any change that Alpine Linux will be supported for pritunl-client?
Best regards,
MacGyver
zach
August 13, 2026, 11:00am
2
If you only need the CLI client it’s very easy to install it directly from the source. The pritunl/pritunl-client repository has information on doing this.
Got a build-script with help of AI; has worked on Alpine Linux 3.24:
#!/bin/sh
set -eu
GO_VERSION="1.25.5"
GO_ARCHIVE="go${GO_VERSION}.linux-amd64.tar.gz"
GO_URL="https://go.dev/dl/${GO_ARCHIVE}"
GO_SHA256="9e9b755d63b36acf30c12a9a3fc379243714c1c6d3dd72861da637f336ebb35b"
SUDO=""
echo "Installiere benötigte Alpine-Pakete ..."
${SUDO} apk add --no-cache \
ca-certificates \
git \
openvpn \
wireguard-tools \
wget \
tar
${SUDO} update-ca-certificates
echo "Installiere Go ${GO_VERSION} ..."
# Cache-Verzeichnis anlegen, falls es noch nicht existiert
mkdir -p "${HOME}/.cache"
rm -rf "${HOME}/.cache/${GO_ARCHIVE}"
wget -O "${HOME}/.cache/${GO_ARCHIVE}" "${GO_URL}"
cd "${HOME}/.cache"
echo "${GO_SHA256} ${GO_ARCHIVE}" | sha256sum -c -
${SUDO} rm -rf /usr/local/go
${SUDO} mkdir -p /usr/local
${SUDO} tar -C /usr/local -xzf "${GO_ARCHIVE}"
rm -f "${GO_ARCHIVE}"
echo "Konfiguriere Go-Umgebung ..."
PROFILE="${HOME}/.profile"
touch "${PROFILE}"
if ! grep -q 'export GOPATH=' "${PROFILE}" 2>/dev/null; then
cat >> "${PROFILE}" <<'EOF'
# Go
export GOPATH="$HOME/go"
export GOROOT="/usr/local/go"
export PATH="/usr/local/go/bin:$GOPATH/bin:$PATH"
fi
export GOPATH="${HOME}/go"
export PATH="/usr/local/go/bin:${GOPATH}/bin:${PATH}"
echo "Go-Version:"
go version
echo "Kompiliere Pritunl Client ..."
go install github.com/pritunl/pritunl-client/service@latest
go install github.com/pritunl/pritunl-client/cli@latest
${SUDO} install -m 0755 \
"${GOPATH}/bin/service" \
/usr/bin/pritunl-client-service
"${GOPATH}/bin/cli" \
echo "Erstelle OpenRC-Service ..."
${SUDO} tee /etc/init.d/pritunl-client >/dev/null <<'EOF'
#!/sbin/openrc-run
name="Pritunl Client Daemon"
description="Pritunl VPN Client Daemon"
command="/usr/bin/pritunl-client-service"
command_background="yes"
pidfile="/run/${RC_SVCNAME}.pid"
respawn_delay=5
depend() {
need localmount
need net
after bootmisc
${SUDO} chmod 0755 /etc/init.d/pritunl-client
echo "Aktiviere und starte Pritunl Client ..."
${SUDO} rc-update add pritunl-client default
${SUDO} rc-service pritunl-client start
echo
echo "Installation abgeschlossen."
echo
echo "Status des Dienstes:"
${SUDO} rc-service pritunl-client status
echo
echo "Verfügbare Befehle:"
echo " sudo pritunl-client add <profile_uri>"
echo " sudo pritunl-client list"
zach
August 13, 2026, 7:54pm
4
All of the full build scripts for Pritunl packages are in the pritunl/pritunl-pacur repository. This can be used with AI to create source installations for other distributions and other packages including the Electron GUI client.
