[2023-1-24 7:21:32][ERROR] Request: JSON parse failed
SyntaxError: Unexpected token ‘<’, "
"… is not valid JSON
at JSON.parse ()
at Response.json (webpack-internal:///./app/Request.js:45:25)
at eval (webpack-internal:///./app/types/ProfileTypes.js:619:37)
at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
[2023-1-24 7:22:27][ERROR] Request: JSON parse failed
at JSON.parse ()
This was in the Client logs a few seconds after that entry (that I shared in orig post) went into the server specific log…
the closest errors in the service logs were from about half an hr earlier when I was still playing with some ovpn stuff…
This appears to be an error requesting the profile logs from the background service. Try deleting all log files in the C:\Users\USERNAME\AppData\Roaming\pritunl and C:\ProgramData\Pritunl directories. Then restart the computer or the Pritunl service. If this doesn’t work delete both the directories and import the profiles again.
[2023-1-30 6:43:59][ERROR] Request: JSON parse failed
SyntaxError: Unexpected token '<', "<html>
"... is not valid JSON
at JSON.parse (<anonymous>)
[2023-1-30 6:44:42][ERROR] Request: JSON parse failed
I changed time zone on the server to make sure they match and same result… (howmany seconds of error would trigger an issue?) I’m puzzled why ovpn works fine but wg gives me the “failed to connect right away”, there is no log output on the server side that I see either… thanks for your help though!
