I’m currently using this code:
import logging
import os
import sys
import json
import time
import uuid
import hmac
import logging
import base64
import urllib3
import hashlib
import requests
BASE_URL = os.environ['PRITUNL_BASE_URL']
API_TOKEN = os.environ['PRITUNL_API_TOKEN']
API_SECRET = os.environ['PRITUNL_API_SECRET']
def auth_request(method, path):
auth_timestamp = str(int(time.time()))
auth_nonce = uuid.uuid4().hex
auth_string = '&'.join([API_TOKEN, auth_timestamp, auth_nonce, method.upper(), path])
auth_signature = base64.b64encode(hmac.new(
API_SECRET.encode('utf-8'), auth_string.encode('utf-8'), hashlib.sha256).digest())
auth_headers = {
'Auth-Token': API_TOKEN,
'Auth-Timestamp': auth_timestamp,
'Auth-Nonce': auth_nonce,
'Auth-Signature': auth_signature,
'Content-Type': 'application/json'
return auth_headers
# Function to call the API, template is optional
def request(method, path, template=None):
try:
return requests.request(method, BASE_URL + path,
headers=auth_request(method, path),
verify=True, data=json.dumps(template)
except Exception as e:
logging.warning(e)
def get_user( user_id):
try:
response = request('GET', '/user/{}'.format(user_id))
print(response.json())
assert(response.status_code == 200)
data = response.json()
for user in data:
print(user)
logging.warning(e)
get_user("619694f4e9025a52daa48130")
I got the token and secret from the user screen and set it to admin
But the response:
python3 pritunl_scripts/get_user.py
WARNING:root:[Errno Extra data] 401 Unauthorized: 4
My envs:
export PRITUNL_BASE_URL="https://${myPritunlZeroHost}.com.br"
export PRITUNL_API_TOKEN="sbe3kBI...redacted"
export PRITUNL_API_SECRET="kNIYz8TL..redacted"
