Hi Pritunl team, hope all is well with you.
We’re currenly figuring out ways to run Pritunl-Zero nodes on Kubernetes.
MongoDB cluster has already been created.
And normally we would run the pritunal-zero mongo command to configure.
We are trying to figure out how to run Pritunl-Zero in Kubernetes with all configuration baked into the image. Basically not having to run the above command when new node is created.
We would like to ask about node ID. In which step does the ID get assigned? Since we’ll not be issuing the configuration command.
Sorry my English is not first language. We really need Pritunl-Zero to be highly available using K8s.
Please kindly advice.
Thank you.
