Hello, when I recently tried to install the SSL Client, the following error occurred:
[root@localhost home]# pritunl-ssh
SERVER:
SSH_KEY: /root/.ssh/id_ed25519.pub
File “/usr/lib64/python3.6/urllib/request.py”, line 1349, in do_open
encode_chunked=req.has_header(‘Transfer-encoding’))
File “/usr/lib64/python3.6/http/client.py”, line 1254, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib64/python3.6/http/client.py”, line 1300, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib64/python3.6/http/client.py”, line 1249, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib64/python3.6/http/client.py”, line 1036, in _send_output
self.send(msg)
File “/usr/lib64/python3.6/http/client.py”, line 974, in send
self.connect()
File “/usr/lib64/python3.6/http/client.py”, line 1415, in connect
server_hostname=server_hostname)
File “/usr/lib64/python3.6/ssl.py”, line 365, in wrap_socket
_context=self, _session=session)
File “/usr/lib64/python3.6/ssl.py”, line 776, in init
self.do_handshake()
File “/usr/lib64/python3.6/ssl.py”, line 1036, in do_handshake
self._sslobj.do_handshake()
File “/usr/lib64/python3.6/ssl.py”, line 648, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:877)
During handling of the above exception, another exception occurred:
File “/usr/bin/pritunl-ssh”, line 631, in
resp = urllib.request.urlopen(req)
File “/usr/lib64/python3.6/urllib/request.py”, line 223, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib64/python3.6/urllib/request.py”, line 526, in open
response = self._open(req, data)
File “/usr/lib64/python3.6/urllib/request.py”, line 544, in _open
‘_open’, req)
File “/usr/lib64/python3.6/urllib/request.py”, line 504, in _call_chain
result = func(*args)
File “/usr/lib64/python3.6/urllib/request.py”, line 1392, in https_open
context=self._context, check_hostname=self._check_hostname)
File “/usr/lib64/python3.6/urllib/request.py”, line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:877)>
This is a test environment I built in the company’s intranet. Every step is based on“ Getting Started SSH ”Let’s do it above.
The only difference: I use acme when creating Lets Encrypt certificates Sh is created locally on the server. In the certificate tab, I selected TEXT to fill in manually instead of LetsEncrypt.
