Pritunl Zero v1.0.3253.94 has been released. This release includes a refactored web code with new themes and LetsEncrypt certificate verification with DNS TXT records.
Refactored Web Code
The web code has been refactored to the latest Blueprint JS version. This adds 2 new themes. The v3 theme was ported to v5 to keep the same appearance by default. Click the dark/light theme icon in the top menu will toggle between dark v3, light v3, dark v5 and light v5. Below are the v3 dark and v5 dark themes. This setting saves in each users settings. There are still some display issues with the v5 theme that will be fixed in future releases.
LetsEncrypt Certificate Verification with DNS TXT
The certificates can now be verified with DNS TXT records using the DNS provider API. Currently AWS, Cloudflare and Oracle Cloud are supported as DNS providers. This allows obtaining certificates without needing to open any ports on the server. The new Secrets tab is used for maintaining the API keys for the DNS providers. These can then be added to a certificate that uses DNS TXT verification.
