Problems installing Pritunl on Ubuntu 22.04 and 24.04
Hello together,
today I wanted to install Pritunl on Ubuntu 22.04 or 24.04 and I’m receiving the error message that the repository is not signed. Here with 24.04:
I can provide the similar screenshot for 22.04 as well if you want.
Unfortunately on the RHEL-Distro installations it seems, that the dny update does seem to consume alot of RAM, is there any way to reduce it? The installation process exits at dny update.
Here the similar error message with 22.04:
Please help, it’s kinda urgent.
Got same problem with installation on Ubuntu (Even tried 20.04, 22.04, 24.04) and Debian 12 also :frowning:
Need help!
This issue started occurring after a change made at 10:34 UTC. There was no such issue when I set it up last night.
CleanShot 2024-10-21 at 15.37.29@2x
The build server was upgraded and these new packages were synced to the server today. The signing key had not been configured yet causing all the packages to remain unsigned. This has been fixed, the cache will need to be cleared before installing the package again.
sudo apt clean
sudo dnf clean all
Great, works again. Thanks!
