Problems with client connecting on Mac - Sequia 15.1.1 (24B91)
Hi
We have had problems after (some) people have upgraded to MacOS 15.1.1. It might not be directly related, but we have not made any other changes to pritunl client or serverside.
There not much to go on, but client logs do log errors, fx from service log:
[2024-11-29 11:28:08][ERRO] ▶ profile: Stopping system profile due to non-interactive single sign-on ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode02.trifork.security", "vpnnode01.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="f65e442ddb72c755" ◆ state_interactive=false ◆ state_no_reconnect=true ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 28, 7, 258317000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
And client log:
[2024-11-29 9:42:29][ERROR] Request:  Client error method=GET path=/sprofile
Error: connect ENOENT /var/run/pritunl.sock
    at PipeConnectWrap.afterConnect [as oncomplete] (node:net:1607:16)
Have tried older versions, running the newest 1.3.4083.
I have tried connecting over different networks, but no success. Also removed the client, and the enclave key, starting on a fresh client install. But no success.
Any idea what could cause this ?
Regards
André
More from servicelog, info messages:
[2024-11-29 11:38:45][INFO] ▶ connection: Attempting remote ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=96 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="authenticating" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ remote="vpnnode01.trifork.security" ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
More servicelog:
profile: Request put error
Post "https://vpnnode02.trifork.security/key/ovpn_wait/65b8f866482b71a658c0c0e1/66260e0fa6088cac1a5e7149/65c49451c5e1bd5e54f2308a/": context canceled
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).EncRequest
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:987 +0x10145b614
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).authorize
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:545 +0x101458ae7
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:564 +0x101458c7b
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:653 +0x10145923b
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).connectPreAuth
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:287 +0x1014572ef
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).Start
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:189 +0x1014564ff
github.com/pritunl/pritunl-client-electron/service/connection.(*Ovpn).Start
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/ovpn.go:107 +0x10145d8cf
github.com/pritunl/pritunl-client-electron/service/connection.(*Connection).Start
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/connection.go:127 +0x10145d8b8
	/opt/homebrew/Cellar/go@1.22/1.22.8/libexec/src/runtime/asm_arm64.s:1222 +0x100f12343
[2024-11-29 11:37:08][INFO] ▶ profile: Connecting ◆ device_auth=true ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_connect=false ◆ force_dns=true ◆ geo_sort="" ◆ mode="ovpn" ◆ profile_id="e93d8f268189f6a4" ◆ reconnect=true ◆ sso_auth=true
[2024-11-29 11:37:08][INFO] ▶ connection: Resolved remotes ◆ public_address="" ◆ public_address6="" ◆ remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ sort_method="random"
[2024-11-29 11:37:08][INFO] ▶ connection: Attempting remote ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ remote="vpn.trifork.security*" ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:08][ERRO] ▶ profile: Global connection timeout ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=180 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="authenticating" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ global_timeout=180 ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:08][ERRO] ▶ connection: Disconnecting ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=180 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="authenticating" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:10][INFO] ▶ utils: Clearing DNS state
[2024-11-29 11:40:10][INFO] ▶ profile: Disconnected with restart ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=true ◆ client_provider=true ◆ client_startime=182 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="disconnected" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=true ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:10][INFO] ▶ connection: Stopping reconnect ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=true ◆ client_provider=true ◆ client_startime=182 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="disconnected" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ reason="restart" ◆ state_closed=true ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=false ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:10][INFO] ▶ profile: Connecting ◆ device_auth=true ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_connect=false ◆ force_dns=true ◆ geo_sort="" ◆ mode="ovpn" ◆ profile_id="e93d8f268189f6a4" ◆ reconnect=true ◆ sso_auth=true
[2024-11-29 11:40:10][INFO] ▶ connection: Resolved remotes ◆ public_address="" ◆ public_address6="" ◆ remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ sort_method="random"
[2024-11-29 11:40:10][INFO] ▶ connection: Attempting remote ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ remote="vpn.trifork.security*" ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:11][INFO] ▶ connection: Stopping non-interactive single sign-on ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:11][INFO] ▶ connection: Stopping reconnect ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ reason="client_auth_error" ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=false ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:11][ERRO] ▶ profile: Stopping system profile due to non-interactive single sign-on ◆ client_disconnect=false ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=true ◆ state_stop=false ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:11][ERRO] ▶ connection: Disconnecting ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=false ◆ client_provider=true ◆ client_startime=0 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="connecting" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=false ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=true ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:17][INFO] ▶ utils: Clearing DNS state
[2024-11-29 11:40:18][INFO] ▶ profile: Disconnected without restart ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=true ◆ client_provider=true ◆ client_startime=7 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="disconnected" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=true ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="c3b4cc0379fb0612" ◆ state_interactive=false ◆ state_no_reconnect=true ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 40, 10, 834549000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
[2024-11-29 11:40:18][ERRO] ▶ connection: Start error ◆ client_disconnect=true ◆ client_disconnect_waiters=0 ◆ client_disconnected=true ◆ client_provider=true ◆ client_startime=189 ◆ data_iface="" ◆ data_mode="" ◆ data_remotes=[]string{"vpn.trifork.security*", "vpnnode01.trifork.security", "vpnnode02.trifork.security"} ◆ data_status="disconnected" ◆ data_timestamp=0 ◆ data_tun_iface="" ◆ ovpn_auth_failed=false ◆ ovpn_cmd=false ◆ ovpn_connected=false ◆ ovpn_dir="" ◆ ovpn_last_auth_failed=-1 ◆ ovpn_management_pass=false ◆ ovpn_management_port=0 ◆ ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" ◆ ovpn_remotes=[]string{} ◆ ovpn_running=0 ◆ ovpn_tap_iface="" ◆ profile_device_auth=true ◆ profile_disable_dns=false ◆ profile_disable_gateway=false ◆ profile_dynamic_firewall=false ◆ profile_force_connect=false ◆ profile_force_dns=true ◆ profile_geo_sort=false ◆ profile_id="e93d8f268189f6a4" ◆ profile_mode="ovpn" ◆ profile_reconnect=true ◆ profile_sso_auth=true ◆ profile_system_profile=true ◆ profile_timeout=false ◆ state_closed=true ◆ state_closed_waiters=0 ◆ state_deadline=false ◆ state_delay=false ◆ state_id="eee4dffad2e35287" ◆ state_interactive=true ◆ state_no_reconnect=true ◆ state_stop=true ◆ state_system_interactive=false ◆ state_temp_paths=[]string{} ◆ state_time=time.Date(2024, time.November, 29, 11, 37, 8, 519492000, time.Local) ◆ wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" ◆ wg_conf_path="" ◆ wg_conf_path2="" ◆ wg_connected=false ◆ wg_last_handshake=0 ◆ wg_path="/Applications/Pritunl.app/Contents/Resources/wg" ◆ wg_priv_key=false ◆ wg_pub_key=false ◆ wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" ◆ wg_server_pub_key=false ◆ wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) ◆ wg_sso_token=false ◆ wg_util_path=""
Post "https://vpnnode01.trifork.security/key/ovpn_wait/65b8f866482b71a658c0c0e1/66260e0fa6088cac1a5e7149/65c49451c5e1bd5e54f2308a/": context canceled
Client log, some errors regarding secure enclave.
[2024-11-29 11:16:6][ERROR] Tpm: Secure enclave exec code error caller_id=Byc9wdkooFw7o1uM exit_code=null output=Swift/ErrorType.swift:253: Fatal error: Error raised at top level: Error Domain=NSOSStatusErrorDomain Code=-25308 "<sepk:p256(u) kid=38e434129d52116a>: unable to sign digest" UserInfo={NSDebugDescription=<sepk:p256(u) kid=38e434129d52116a>: unable to sign digest, AKSError=-536870174}
[2024-11-29 11:16:6][ERROR] Tpm: Secure enclave exec code error caller_id=DBuOcB4eCfo1ju1w exit_code=null output=Swift/ErrorType.swift:253: Fatal error: Error raised at top level: Error Domain=NSOSStatusErrorDomain Code=-25308 "<sepk:p256(u) kid=38e434129d52116a>: unable to sign digest" UserInfo={NSDebugDescription=<sepk:p256(u) kid=38e434129d52116a>: unable to sign digest, AKSError=-536870174}
[2024-11-29 11:16:15][ERROR] Tpm: Secure enclave process timed out caller_id=Byc9wdkooFw7o1uM
[2024-11-29 11:16:16][ERROR] Tpm: Secure enclave process timed out caller_id=DBuOcB4eCfo1ju1w
The Secure Enclave error is causing the other errors. Delete the file /Library/Application Support/Pritunl/pritunl-client.json to clear the Secure Enclave derived key input. Opening the macOS Keychain app may either show more errors or correct issues with the Secure Enclave.
There is also an issue with a * in the domain. This should not be in the host public address or sync address fields.
The * I do not know where comes from.
I guess the vpn.trifork.secuirty is from: pritunl-client/profiles/e93d8f268189f6a4.conf
“sync_hosts”:[“https://vpn.trifork.security”]
But I am not sure ? Because I do not see the “*” anywhere I can find.
I have tried opening the keychain, and delteing that json file. But I still get the same error. I have also totally uninstalled, and removed the secure enclave refencre - via the uninstall script.
Hi again, just fyi
We upgraded the serverside to newest version, and downgraded the client to 1.3.4026.10 - this seems to be a stable configuration.
André
