I thought I would start a new topic
I updated my client to v1.3.4059 on Saturday or Sunday , and Sunday evening I went to my laptop and it had been trying to reconnect for a few hours.
It just occured this evening now, before bed I checked my pc and it had been constantly reconnecting for 4 hours, which of course locks my account on radius.
The weird thing is I have auto reconnect disabled on the server and on the client
We authenticate to radius , which then sends auth to privacyidea for tfa and further LDAP auth. (Users tfa is combined with their password)
Its really important that we can stop auto reconnect as the password+tfa will not be valid for reconnects and this causes accounts to be locked out.
[2024-10-29 01:53:59][INFO] βΆ connection: Stopping reconnect β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="client_auth_error" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 53, 58, 390737000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:02][ERRO] βΆ connection: Disconnecting β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=3 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 53, 58, 390737000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:05][INFO] βΆ utils: Clearing DNS state
[2024-10-29 01:54:05][INFO] βΆ profile: Disconnected with restart β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=true β client_provider=true β client_startime=7 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="disconnected" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=true β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 53, 58, 390737000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:05][INFO] βΆ profile: Connecting β device_auth=false β disable_dns=false β disable_gateway=false β dynamic_firewall=false β force_connect=false β force_dns=false β geo_sort="" β mode="wg" β profile_id="eed40e6e46a19ead" β reconnect=false β sso_auth=false
[2024-10-29 01:54:05][INFO] βΆ connection: Resolved remotes β public_address="" β public_address6="" β remotes=[]string{"redacted"} β sort_method="random"
[2024-10-29 01:54:05][INFO] βΆ connection: Attempting remote β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β remote="redacted" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:06][INFO] βΆ connection: Authorization failed β allow=false β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="Too many authentication attempts" β remote="" β remote6="" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:06][ERRO] βΆ profile: Failed to authenticate β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="Too many authentication attempts" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:06][INFO] βΆ connection: Stopping reconnect β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="client_auth_error" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:09][ERRO] βΆ connection: Disconnecting β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=3 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:12][INFO] βΆ utils: Clearing DNS state
[2024-10-29 01:54:12][INFO] βΆ profile: Disconnected with restart β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=true β client_provider=true β client_startime=7 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="disconnected" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=true β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 5, 477151000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:12][INFO] βΆ profile: Connecting β device_auth=false β disable_dns=false β disable_gateway=false β dynamic_firewall=false β force_connect=false β force_dns=false β geo_sort="" β mode="wg" β profile_id="eed40e6e46a19ead" β reconnect=false β sso_auth=false
[2024-10-29 01:54:12][INFO] βΆ connection: Resolved remotes β public_address="" β public_address6="" β remotes=[]string{"redacted"} β sort_method="random"
[2024-10-29 01:54:12][INFO] βΆ connection: Attempting remote β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β remote="redacted" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:13][INFO] βΆ connection: Authorization failed β allow=false β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="Too many authentication attempts" β remote="" β remote6="" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:13][ERRO] βΆ profile: Failed to authenticate β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="Too many authentication attempts" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:13][INFO] βΆ connection: Stopping reconnect β client_disconnect=false β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=0 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β reason="client_auth_error" β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=false β state_stop=false β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:16][ERRO] βΆ connection: Disconnecting β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=false β client_provider=true β client_startime=3 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="connecting" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=false β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:19][INFO] βΆ utils: Clearing DNS state
[2024-10-29 01:54:19][INFO] βΆ profile: Disconnected without restart β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=true β client_provider=true β client_startime=7 β data_iface="" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="disconnected" β data_timestamp=0 β data_tun_iface="" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=true β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=false β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{} β state_time=time.Date(2024, time.October, 29, 1, 54, 12, 570437000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="" β wg_conf_path2="" β wg_connected=false β wg_last_handshake=0 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=false β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
[2024-10-29 01:54:21][ERRO] βΆ profile: Watch connection error β client_disconnect=true β client_disconnect_waiters=0 β client_disconnected=true β client_provider=true β client_startime=48249 β data_iface="pritunl0" β data_mode="" β data_remotes=[]string{"redacted"} β data_status="disconnected" β data_timestamp=0 β data_tun_iface="utun10" β ovpn_auth_failed=false β ovpn_cmd=false β ovpn_connected=false β ovpn_dir="" β ovpn_last_auth_failed=-1 β ovpn_management_pass=false β ovpn_management_port=0 β ovpn_path="/Applications/Pritunl.app/Contents/Resources/pritunl-openvpn" β ovpn_remotes=[]string{} β ovpn_running=0 β ovpn_tap_iface="" β profile_device_auth=false β profile_disable_dns=false β profile_disable_gateway=false β profile_dynamic_firewall=false β profile_force_connect=false β profile_force_dns=false β profile_geo_sort=false β profile_id="eed40e6e46a19ead" β profile_mode="wg" β profile_reconnect=false β profile_sso_auth=false β profile_system_profile=false β profile_timeout=false β state_closed=true β state_closed_waiters=0 β state_deadline=false β state_delay=false β state_interactive=true β state_no_reconnect=true β state_stop=true β state_system_interactive=false β state_temp_paths=[]string{"/etc/wireguard/pritunl0.conf"} β state_time=time.Date(2024, time.October, 28, 12, 30, 11, 546149000, time.Local) β wg_bash_path="/Applications/Pritunl.app/Contents/Resources/bash" β wg_conf_path="/etc/wireguard/pritunl0.conf" β wg_conf_path2="" β wg_connected=true β wg_last_handshake=1730118615 β wg_path="/Applications/Pritunl.app/Contents/Resources/wg" β wg_priv_key=true β wg_pub_key=true β wg_quick_path="/Applications/Pritunl.app/Contents/Resources/wg-quick" β wg_server_pub_key=true β wg_sso_start=time.Date(1, time.January, 1, 0, 0, 0, 0, time.UTC) β wg_sso_token=false β wg_util_path=""
profile: Request put error
Put "https://10.0.60.1/key/wg/redacted": read tcp 10.0.60.20:63051->10.0.60.1:443: read: connection reset by peer
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).EncRequest
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:979 +0x102e17444
github.com/pritunl/pritunl-client-electron/service/connection.(*Wg).ping
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/wg.go:395 +0x102e2c9db
github.com/pritunl/pritunl-client-electron/service/connection.(*Wg).WatchConnection
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/wg.go:300 +0x102e2c2f3
github.com/pritunl/pritunl-client-electron/service/connection.(*Client).Start.func1
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/connection/client.go:216 +0x102e125fb
/opt/homebrew/Cellar/go@1.22/1.22.8/libexec/src/runtime/asm_arm64.s:1222 +0x1028ce343
