Our Let’s Encrypt certificate expired and we could not connect to the WebUI via Chrome or Firefox (Luckily, there are still browsers that can).
We tried running pritunl reset-ssl-cert and received the “Server ssl certificate successfully reset” message but now the webUI isn’t even running. Not sure what steps to take next
Adding some detail: The first time I ran reset-ssl-cert the following appeared in the log:
[evening-thunder-9118][2022-12-12 08:59:32,707][INFO] Settings changed, restarting server…
ssl_changed = false
cert_changed = true
key_changed = true
port_changed = false
redirect_server_changed = false
reverse_proxy_changed = false
[evening-thunder-9118][2022-12-12 08:59:33,318][INFO] Server restarting…
[evening-thunder-9118][2022-12-12 08:59:33,368][INFO] Starting server
selinux_context = “none”
[evening-thunder-9118][2022-12-12 08:59:33,368][INFO] Generating server certificate…
[evening-thunder-9118][2022-12-12 08:59:33,432][ERROR] Popen returned error exit code
cmd = [“openssl”, “ecparam”, “-name”, “secp384r1”, “-genkey”, “-noout”, “-out”, “/tmp/pritunl_45a70cb6026e4b98b523fd1111b27402/server.key”]
return_code = 1
And then the /tmp/pritunl_45a70cb6026e4b98b523fd1111b27402 folder disappeared
