I have a fresh Pritunl Enterprise installation. running server version v1.32.3552.76 f7b4e4
i’ve installed a fresh client version v1.3.3484.2.
i have configured radius to work with active directory - that’s all fine.
i’ve enabled 2FA on the server - that’s all fine.
when i go to connect to the server for the first time, i am prompted for the password and the 2FA code and it connects with no issues. if i disconnect and then reconnect again, it only prompts for the password. if i enter the correct password it fails to connect and i receive the error in red at the bottom of the client:
Failed to authenticate to (name of server) (name of client)
if i then wait until it’s disconnected and press connect again, it prompts me for the password and 2FA.
so it works correctly every second time.
is this a known issue? or is there a setting somewhere i can change to remediate this problem and enforce 2FA for each login?
cheers, Wiz!!
