I hit some obstacles running Pritunl on Oracle Linux 8, maybe this can be useful for others. Maybe this footgun can also be added to the docs, as Oracle Linux 8 is the recommended distro to run Pritunl on.
I use the official Oracle Linux 8 Vagrant VM from https://yum.oracle.com/boxes/ . In other words, the VM is created like this:
$ vagrant init oraclelinux/8 https://oracle.github.io/vagrant-projects/boxes/oraclelinux/8.json
$ vagrant up
$ vagrant ssh
Note that Oracle Linux 8 uses the “UEK / Unbreakable Enterprise Kernel” v5.15 by default as seen here:
[vagrant@localhost ~]$ uname -a
Linux localhost.localdomain 5.15.0-3.60.5.1.el8uek.x86_64 #2 SMP Wed Oct 19 20:04:48 PDT 2022 x86_64 x86_64 x86_64 GNU/Linux
Then I followed the instructions from Installation .
I created an openvpn server in the web UI, but starting the openvpn server fails like this (full logs see my reply)
[lively-refuge-1534][2023-03-18 14:17:13,463][ERROR] Popen returned error exit code
cmd = ["ipset", "create", "6415c7e90c98ebdaaeff4373_or", "hash:net", "family", "inet"]
return_code = 1
Process stderr:
ipset v7.1: Kernel error received: set type not supported
Switching to the “Red-Hat Compatible Kernel” (see my reply for how to switch) fixed the issue and Pritunl now works:
[root@localhost ~]# uname -a
Linux localhost.localdomain 4.18.0-425.13.1.el8_7.x86_64 #1 SMP Tue Feb 21 15:09:05 PST 2023 x86_64 x86_64 x86_64 GNU/Linux
[lively-refuge-1534][2023-03-18 14:21:13,735][INFO] Starting server
selinux_context = "system_u:system_r:pritunl_t:s0"
[lively-refuge-1534][2023-03-18 14:22:42,308][INFO] Starting vpn server
server_id = "6415c7260c98ebdaaeff42be"
instance_id = "6415c9324a6510712a6532db"
instances = []
instances_count = 0
route_count = 1
network = "192.168.222.0/24"
network6 = "fd00:c0a8:de00::/64"
dynamic_firewall = false
host_id = "c8b828dc15da4f9e9d6a7cd23aced905"
host_address = "192.168.122.148"
host_address6 = "fe80::5054:ff:fe14:8483"
host_networks = ["192.168.122.0/24"]
cur_timestamp = "2023-03-18 14:22:42.307679"
libipt = false
