Split Tunnel?
Hi everyone
Is there a way to enable split tunneling with pritunel server?
Here is an explanation of what is split tunneling.
What is split-tunneling?
Split-tunneling is the process of allowing a remote VPN user to access a public network, such as the Internet, at the same time that the user is allowed to access resources on the VPN. This system of network access enables the user to access remote networks, at the same time as accessing the public network.
When you set up split tunneling, only traffic that is destined for the subnets on your Internal LAN will go through the VPN tunnel. Other traffic will go through your employee’s regular internet traffic. Because split tunneling is utilizing the user’s own internet traffic, it doesn’t slow down the company’s network as a whole.
Thanks
This is done by removing the 0.0.0.0/0 route from the server routes.
