We have install pritunl zero on ubuntu 22.04 machine.
We already follow the pritunl zero documentation but still confuse step by step to config pritunl zero as a bastion host.
Is there any guide step by step sequence that we can follow ? Which part that we must config first and verify it then continue to the next config.
The repositories documentation has all the available repositories. There isn’t any documentation for each tab, clicking the ? icon next to options will provide information. The configuration is stored in the MongoDB database.
The server can create a bastion host in a pod container but it should not be the SSH server on the host. Bastion SSH hosts are an advanced configuration that should only be done with full knowledge of complex SSH configurations. Even when done correctly it is far less secure than a configuration with a VPN server to provide the first layer of access control.
