My client cannot connect successfully
Disconnect
Settings
Profiles: Profile connect failed RequestError: Request: Timeout error ssl=false hostname=127.0.0.1 port=9770 method=POST path=/profile
Disconnect
Settings
Click logs in the top right menu and select the service and profile logs for more information.
service log
[2023-08-29 09:21:39][INFO]
main: Service starting ◆ version=“1.3.3600.11”
[2023-08-29 09:22:05][INFO]
profile: Connecting ◆ device_auth=false ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=false ◆ mode=“ovpn” ◆
profile_id=“c2a782bf6879f0898562097f0bea2473” ◆ reconnect=true ◆ sso_auth=false
client log
[2023-8-29 9:21:59][ERROR] Request: Timeout error ssl=true hostname=(my ip) port=443 method=GET path=/key/sync/6279e0e8b7b811dfb7130b11/6279e0e9b7b811dfb7130b2e/6279e3f4b7b811dfb7130d74/263c6a4742902efca2f5ef0b3ba8fdda ttl=5000
RequestError: Request: Timeout error ssl=true hostname=183.2.185.111 port=443 method=GET path=/key/sync/6279e0e8b7b811dfb7130b11/6279e0e9b7b811dfb7130b2e/6279e3f4b7b811dfb7130d74/263c6a4742902efca2f5ef0b3ba8fdda ttl=5000
at Request_Request.parseError (file:///C:/Program%20Files%20(x86)/Pritunl/resources/app.asar/dist/static/app.d143b5.js:60295:16)
at ClientRequest. (file:///C:/Program%20Files%20(x86)/Pritunl/resources/app.asar/dist/static/app.d143b5.js:60335:36)
at ClientRequest.emit (node:events:513:28)
at TLSSocket.emitRequestTimeout (node:_http_client:848:9)
at Object.onceWrapper (node:events:627:28)
at TLSSocket.emit (node:events:525:35)
at Socket._onTimeout (node:net:570:8)
at listOnTimeout (node:internal/timers:569:17)
at process.processTimers (node:internal/timers:512:7)
[2023-8-29 9:21:59][ERROR] Profiles: Failed to sync profile configuration
[2023-8-29 9:21:59][ERROR] Request: Client error ssl=true hostname=183.2.185.111 port=443 method=GET path=/key/sync/6279e0e8b7b811dfb7130b11/6279e0e9b7b811dfb7130b2e/6279e3f4b7b811dfb7130d74/263c6a4742902efca2f5ef0b3ba8fdda ttl=5000
[2023-8-29 9:22:5][INFO] Profiles: Updating profile ‘c2a782bf6879f0898562097f0bea2473’
[2023-8-29 9:22:25][ERROR] Request: Client error ssl=false hostname=127.0.0.1 port=9770 method=POST path=/profile
at Socket.emitRequestTimeout (node:_http_client:848:9)
at Socket.emit (node:events:525:35)
[2023-8-29 9:22:25][ERROR] Request: Timeout error ssl=false hostname=127.0.0.1 port=9770 method=POST path=/profile
[2023-8-29 9:22:25][ERROR] Profiles: Profile connect failed
The connection to the VPN server is timing out. You can try deleting the profile and importing it again to verify the correct IP address and configuration is installed. It may also be a firewall or issue with the server.
