Tls-crypt in pritunl official client
Hey. I’ve created a PR that adds tls-crypt support for pritunl client - not sure if anyone checks GitHub PRs because no default maintainers and actions assigned.
PR link: tls-crypt support by Upgreydd · Pull Request #87 · pritunl/pritunl-client-electron · GitHub
/cc @zach
This will be included in the next client release.
@zach Thanks. Can you please clarify est. date of release?
It should be available in 2-3 weeks.
@zach Thank you for releasing the client. Can I ask when are you planning to reflect the latest version (as of now v1.3.3883.60) download links to https://client.pritunl.com ?
I need to make around ~200 people update their clients and the GitHub Releases page is not the friendliest thing for non-technical people. :pray:
The homepage typically isn’t updated for a while unless there is an issue with a previous version. This allows time to find issues before more users download the update. This latest release was primarily done to support newer Linux distributions.
This feature isn’t going to fully work until the server is also modified to support it. You would need to either have a different OpenVPN server or made modifications to the Pritunl server database.
