Hello.
I bought the enterprise version, because i thought this error leave, but i keep still have this error.
After i install the system all works fine for a some hours, or days, then sistematicly got this error and the client can not connect anymore. No matter the client, still have same problem.
I did many many try in dfferent vps, and i still have this problem, always.
I am in china, but the vps i did at home in italy, or usa, or uk. No difference, still the same.
If i create a new server and download the user again it will work again for a few, before start to vive the same error afain.
Anyone knows how can i solve it?
Thanks
[frankfurt] Fri Mar 17 14:17:47 2023 125.111.90.114 TLS Error: incoming packet authentication failed from [AF_INET6]::ffff:125.111.90.114:27609
[frankfurt] Fri Mar 17 14:17:48 2023 125.111.90.114 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1 / time = (1679059127) Fri Mar 17 14:18:47 2023 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
[frankfurt] Fri Mar 17 14:17:48 2023 125.111.90.114 TLS Error: incoming packet authentication failed from [AF_INET6]::ffff:125.111.90.114:27609
[frankfurt] Fri Mar 17 14:17:49 2023 125.111.90.114 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
[frankfurt] Fri Mar 17 14:17:49 2023 125.111.90.114 TLS Error: TLS handshake failed
