TLS/SSL SMTP fail regardless of port/tls/ssl
Attempting to set up smtp, unable to get any combination of settings to work.
Using SMTP2GO, have tried all ports (:25, 2525, 587, 465, 443) - all attempts fail and appear to indicate that the python version used by Pritunl is outdated, though the server’s python version is updated (3.12).
Tested via a 365-connector / port25 and was able to get this to connect, but unable to get anything beyond this error when using smtp2go.
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/handlers/user.py”, line 724, in user_put
user.send_key_email(utils.get_url_root())
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/user/user.py”, line 1667, in send_key_email
utils.send_email(
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/mail.py”, line 40, in send_email
smtp_conn.starttls(context=context)
File “/usr/lib/pritunl/usr/lib/python3.9/smtplib.py”, line 790, in starttls
self.sock = context.wrap_socket(self.sock,
File “/usr/lib/pritunl/usr/lib/python3.9/ssl.py”, line 501, in wrap_socket
return self.sslsocket_class._create(
File “/usr/lib/pritunl/usr/lib/python3.9/ssl.py”, line 1076, in _create
self.do_handshake()
File “/usr/lib/pritunl/usr/lib/python3.9/ssl.py”, line 1345, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: SSLV3_ALERT_ILLEGAL_PARAMETER] sslv3 alert illegal parameter (_ssl.c:1147)
This has been fixed in pritunl/pritunl@963f850 and will be included in the next release. The file can be manually patched by editing /usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/mail.py then running sudo systemctl restart.
