Too many routes - Split-Tunneling Server
Hi, I’m having an issue with my Pritunl server, which is configured with split tunneling. I want to add approximately 20 routes (using NAT) to access different servers. However, when I add that many routes, none of them work. If I specify only 4 or 5 routes, they work fine.
What could be the cause of that phenomenon? Is there a limitation on Pritunl that I don’t know about?
There’s no limits on the number of routes since around version 1.32 when it was redesigned. It’s tested with 950 routes.
Verify the routes are not overlapping the public IP of the server or interfering with anything. If the routes overlap the public IP of the server a route with the server public IP must be added with the net gateway option enabled.
