Hi, Team.
I’m using latest version of pritunl client (1.3.3283.46) on Windows 10 x64 machine.
I’ve recently upgraded the version from 1.2.2732.2 and I can’t connect to the OpenVPN server.
The log says,
2022-09-09 14:38:13 Windows version 10.0 (Windows 10 or greater) 64bit/n
2022-09-09 14:38:13 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10/n
2022-09-09 14:38:13 ERROR: Auth username is empty/n
2022-09-09 14:38:13 Exiting due to fatal error/n
Enter Auth Username:Enter Auth Password:
/n
And here’s my profile configuration
persist-key
reneg-sec 0
auth-nocache
auth-user-pass C:/username.txt
verb 4
key-direction 1
The same profile still works fine with the older version of Pritunl client.
Also, when I try to connect using openvpn.exe file in the
“C:\Program Files (x86)\Pritunl\openvpn” using same profile, it works fine.
“C:\Program Files (x86)\Pritunl\openvpn” myprofile.ovpn
Is there any workaround to solve this problem?
Thanks.
