Unable to correct problems
in the way of installing Pritunl exactly in the latest levels when I wanna execute this command :
“sudo apt --assume-yes install pritunl mongodb-org”
Ubunto show me this error :
"The following packages have unmet dependencies: pritunl : Depends: python3-distutils but it is not installable E: Unable to correct problems, you have held broken packages. "
what is the solution?
This should be fixed in the 24.04 release in the [unstable repositories][((Repositories).
now i see new error “Unable to locate package pritunl” !?
Below are the commands to install Pritunl on Ubuntu 24.04
sudo tee /etc/apt/sources.list.d/mongodb-org.list << EOF
deb [ signed-by=/usr/share/keyrings/mongodb-server-7.0.gpg ] https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/7.0 multiverse
sudo tee /etc/apt/sources.list.d/openvpn.list << EOF
deb [ signed-by=/usr/share/keyrings/openvpn-repo.gpg ] https://build.openvpn.net/debian/openvpn/stable noble main
sudo tee /etc/apt/sources.list.d/pritunl.list << EOF
deb [ signed-by=/usr/share/keyrings/pritunl.gpg ] https://repo.pritunl.com/unstable/apt noble main
sudo apt --assume-yes install gnupg
curl -fsSL https://www.mongodb.org/static/pgp/server-7.0.asc | sudo gpg -o /usr/share/keyrings/mongodb-server-7.0.gpg --dearmor --yes
curl -fsSL https://swupdate.openvpn.net/repos/repo-public.gpg | sudo gpg -o /usr/share/keyrings/openvpn-repo.gpg --dearmor --yes
curl -fsSL https://raw.githubusercontent.com/pritunl/pgp/master/pritunl_repo_pub.asc | sudo gpg -o /usr/share/keyrings/pritunl.gpg --dearmor --yes
sudo apt update
sudo apt --assume-yes install pritunl openvpn mongodb-org wireguard wireguard-tools
sudo ufw disable
sudo systemctl start pritunl mongod
sudo systemctl enable pritunl mongod
Can I ask you for the same commands but for Ubuntu 25.04?
