I’ve recently activated my copy of the Pritunl Enterprise VPN account. And I’ve created the server and setup a private network to access my server remotely. This can be done by routing the server subnet to the VPN server as stated in the Pritunl instructions.
The VPN server will start. However, nothing will display on the Server Output tab of the web portal. But when I check the log in the Pritunl log file. I get the following error
[snowy-plains-5952][2023-01-10 01:36:46,749][ERROR] Server error occurred while running
File "/usr/lib/pritunl/lib/python3.9/site-packages/pritunl-1.30.3388.46-py3.9.egg/pritunl/server/instance.py", line 1582, in _run_thread
self.iptables.upsert_rules()
File "/usr/lib/pritunl/lib/python3.9/site-packages/pritunl-1.30.3388.46-py3.9.egg/pritunl/iptables.py", line 1411, in upsert_rules
self._insert_iptables_rule(rule, tables=tables)
File "/usr/lib/pritunl/lib/python3.9/site-packages/pritunl-1.30.3388.46-py3.9.egg/pritunl/iptables.py", line 1229, in _insert_iptables_rule
return self._insert_iptables_rule_cmd(rule, ipv6)
File "/usr/lib/pritunl/lib/python3.9/site-packages/pritunl-1.30.3388.46-py3.9.egg/pritunl/iptables.py", line 1211, in _insert_iptables_rule_cmd
utils.Process(
File "/usr/lib/pritunl/lib/python3.9/site-packages/pritunl-1.30.3388.46-py3.9.egg/pritunl/utils/proc.py", line 88, in run
raise subprocess.CalledProcessError(
subprocess.CalledProcessError: Command '['iptables', '-I', 'INPUT', '-i', 'tun4', '-m', 'set', '--match-set', '63bcc12c5eb9da02e3aaa815_or', 'dst', '-j', 'ACCEPT', '-m', 'comment', '--comment', 'pritunl-63bcbb5d5eb9da02e3aaa3d7']' returned non-zero exit status 2.
server_id = "21bcbb5d5eb9da02e3aaa3d7"
instance_id = "63bcc12c5eb34a02e3aaa815"
[snowy-plains-5952][2023-01-10 01:36:46,750][ERROR] Popen returned error exit code
cmd = ["iptables", "-I", "INPUT", "-i", "tun4", "-m", "set", "--match-set", "63bcc12c5eb9da02e3aaa815_or", "dst", "-j", "ACCEPT", "-m", "comment", "--comment", "pritunl-63bcbb5d5eb9da02e3aaa3d7"]
timeout = 15
return_code = 2
What are the potential issues causing this problem? And what are the possible solutions?
Thanks,
