I would like to understand whether it is possible to use own SSL certificate both for Pritunl UI and the server/s?
If so what is required to achieve the goal ?
Thank you.
Thank you.
It’s in the advanced settings in the top right, it’s only available with an enterprise subscription.
I can see such configuration only for the web interface, what about the VPN serverss themself, what about wg server/s also ?
Custom certificates can’t be used for the VPN servers.
