Using PritunlVPN client as a gateway
Is it possible to use any client connected to the VPN server as a gateway? If so, could you share details on how this can be achieved?
Here is the setup:
  • Service in Network X has access to the VPN host and the clients connected to the VPN server in Network Y ( in AWS )
  • This service tries to reach another service running in Network Z ( remote data center ) via a VPN client that is also connected to the VPN server and resides in the same Network Z.
Thank you,
Kristiyan
This is documented in the user network links, it requires adding a static route to the router on the remote network with a next hop of the VPN client local IP.
