I’ve just installed the VPN client (v1.2.3128.59) on a Mac (Apple Silicon / ARM). When trying to start to connect to a VPN server, it immediately disconnects. I’ve also tried installing from the Github source (1.2.3154.57).
The log from the service, of the built version from github states:
[2022-05-18 20:28:39][ERRO]
profile: Panic ◆ panic=runtime.boundsError{x:50, y:37, signed:true, code:0x3} ◆ stack=“goroutine 119 [running]:\nruntime/debug.Stack()\n\t/opt/homebrew/Cellar/go/1.18.2/libexec/src/runtime/debug/stack.go:24 +0x68\ngithub/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn.func3.1()\n\t/Users/xxxxxx/pritunl-client-electron/build/macos/Applications/Pritunl-darwin-x64/pritunl-client-electron-1.2.3154.57/service/go/src/github/pritunl/pritunl-client-electron/service/profile/profile.go:1424 +0x80\npanic({0x104db3100, 0x140003e80f0})\n\t/opt/homebrew/Cellar/go/1.18.2/libexec/src/runtime/panic.go:838 +0x204\ngithub/pritunl/pritunl-client-electron/service/profile.(*Profile).parseLine(0x1400022e380, {0x140004df000, 0x32})\n\t/Users/xxxx/Sites/pritunl-client-electron/build/macos/Applications/Pritunl-darwin-x64/pritunl-client-electron-1.2.3154.57/service/go/src/github/pritunl/pritunl-client-electron/service/profile/profile.go:904 +0xabc\ngithub/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn.func3()\n\t/Users/xxxx/pritunl-client-electron/build/macos/Applications/Pritunl-darwin-x64/pritunl-client-electron-1.2.3154.57/service/go/src/github/pritunl/pritunl-client-electron/service/profile/profile.go:1439 +0x80\ncreated by github/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn\n\t/Users/xxxx/pritunl-client-electron/build/macos/Applications/Pritunl-darwin-x64/pritunl-client-electron-1.2.3154.57/service/go/src/github/pritunl/pritunl-client-electron/service/profile/profile.go:1419 +0xe20\n”
Log from the package:
[2022-05-19 09:01:55][INFO]
main: Service starting ◆ version=“1.2.3154.57”
[2022-05-19 09:02:16][INFO]
profile: Connecting ◆ mode=“ovpn” ◆ profile_id=“a56a8df10e448f2478bb67384450b0fb”
[2022-05-19 09:02:16][WARN]
parser: Configuration line [2] ◆ line=“remote xx.xx.xx.xx 443”
profile: Profile exit, reconnecting ◆ profile_id=“a56a8df10e448f2478bb67384450b0fb”
[2022-05-19 09:02:17][INFO]
profile: Disconnected ◆ profile_id=“a56a8df10e448f2478bb67384450b0fb”
I’ve tried different VPN profiles (NordVPN and from my own server as well) and they all give the same error. When using another VPN client, it does seem to work.
Edit: The same seems to happen on Windows as well.
