A bit of the same as HTTP Security Headers just for the VPN server
We have the following risk alerts from securityscorecard.com regarding Pritunl VPN webUI:
- Site Does Not Use Best Practices Against Embedding of Malicious Content
- Content Security Policy Contains Broad Directives
So let’s help the community by setting the same standard at the source
What we are triggered on, we need a value for the “X-Frame-Options” see Recommendations for guidelines
Description
The X-Frame-Options is an HTTP header that controls whether a web page can be displayed within an iframe. It prevents clickjacking attacks by allowing webmasters to specify if their site can be embedded in frames on other domains. This header helps protect against unauthorized framing of a website’s content, enhancing the overall security of web applications.
Risk
Not using X-Frame-Options means greater vulnerability to clickjacking attacks. Without this security header, web pages are susceptible to being embedded within iframes on other domains without explicit permission. Clickjacking involves maliciously presenting a framed web page to deceive users into interacting with altered content. This can lead to various security threats, including unauthorized access, data theft, or unintended user actions on legitimate websites.
Recommendations
- Implement X-Frame-Options with the ‘SAMEORIGIN’ directive to allow framing only from the same origin.
- Include the Content Security Policy (CSP) directive frame-ancestors “self” to allow framing from the same origin.
- Consider using frame-ancestors “none” to disallow all framing.
What we are triggered on, we have set the value “upgrade-insecure-requests” but that is to broad
Description
A Content Security Policy (CSP) is a security standard implemented by web browsers to guard against Cross-Site Scripting (XSS) attacks. This policy is defined by HTTP headers sent by the web server and instructs the browser on which resources are allowed to load for a particular web page. By specifying trusted domains for script execution, plug-ins, and other resources, a CSP helps prevent malicious code injection and enhances the overall security of web applications. It acts as a crucial layer of defense, ensuring that only authorized sources are permitted.
Risk
When a Content Security Policy (CSP) is configured with overly broad settings, it opens the door to potential security vulnerabilities. In such cases, directives like ‘script-src’, ‘object-src’, or ‘default-src’ may be defined with permissive values like ‘http:’, ‘’, or ‘http://’. This allows the browser to load resources from a wide range of sources, including potentially malicious domains. This lack of specificity compromises the intended protection against Cross-Site Scripting (XSS) attacks as adversaries could inject and execute malicious scripts.
Recommendations
- Specify exact domains for trusted sources in directives like ‘script-src’ and ‘style-src’ instead of using overly broad values like ‘’, ‘http:’, or ‘http://’.
- Minimize the use of wildcard characters and avoid permissive settings to enhance the precision of the Content Security Policy (CSP).
- Utilize HTTPS to secure connections and minimize risks associated with loading resources from untrusted or potentially unsecure sources.
- Implement nonce or hash values for inline scripts to maintain security while allowing specific exceptions.
- Regularly review and update the CSP configuration to adapt to changes in the application and address emerging security concerns.
- Test and monitor the CSP to ensure its effectiveness, identifying and addressing any unexpected behavior or attempts to bypass security measures.
- Educate development teams on the importance of a well-defined and specific CSP to strengthen overall web security.
