I’m attempting to run Pritunl in an EKS cluster. I followed the docs for adding Pritunl (web) behind a load balancer and it works as expected.
I run the following as documented:
sudo pritunl set app.reverse_proxy true
sudo pritunl set app.redirect_server false
sudo pritunl set app.server_ssl false
sudo pritunl set app.server_port 80
However, when I create [VPN] Server in the web console and attempt to start it, the web console crashes. It appears that the VPN server continues to run until I recover it is to run
pritunl repair-database
at which point the VPN server stops and the web console returns. The error logs point to something which I think is unlikely to be an issue:
Application Logs (from clicking the logs button in the top right hand corner):
[evening-stars-3730][2023-12-04 11:59:55,721][ERROR] Instance doc lost, stopping server. Check datetime settings
I’ve checked this error, the date/time is as expected.
System logs:
result = sock_info.command(
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pymongo/pool.py", line 769, in command
self._raise_connection_failure(error)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pymongo/pool.py", line 969, in _raise_connection_failure
_raise_connection_failure(self.address, error)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pymongo/pool.py", line 257, in _raise_connection_failure
raise NetworkTimeout(msg)
pymongo.errors.NetworkTimeout: pritunl-mongodb:27017: timed out
MongoDB also appears to be behaving as expected despite this error message.
Is this a bug in the software? Or am I misconfiguring something?
