In the admin portal, in the Users page, my connections all appears from the device name “linux device”. Would it be possible to make the terminal openvpn client push the hostname?
Thanks
Thanks
The device name is set with the OpenVPN option setenv UV_NAME.
On linux, can that be done via network manager?
The NetworkManager VPN client filters all VPN options. I’m not sure if that option is included, it isn’t shown anywhere in the interface. You can try using the commands in the Gnome Client documentation to import the configuration file with the options set.
