When I try to connect using Wireguard to our VPN servers the connection fails since upgrade to v1.30.3221.67. After some investigation, the issue appears to be in the pritunl/handlers/key.py > key_wg_post method (POST /key/wg/<org_id>/<user_id>/<server_id> handler) here.
The if condition checks if the remote_addr is IPv6 by relying on the presence of ‘:’ character, however in our case the remote_addr variable contains the port as well, e.g. 11.22.33.44:12345. Because the code checks for ‘:’ it gets interpreted as IPv6, failing the connection with WireGuard. The stacktrace is the following:
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/handlers/key.py", line 1059, in key_wg_post remote_addr = str(ipaddress.IPv6Address(remote_addr)) File "/usr/lib/pritunl/usr/lib/python3.9/ipaddress.py", line 1915, in __init__ self._ip = self._ip_int_from_string(addr_str) File "/usr/lib/pritunl/usr/lib/python3.9/ipaddress.py", line 1628, in _ip_int_from_string raise AddressValueError(msg) ipaddress.AddressValueError: At least 3 parts expected in '11.22.33.44:12345'
Could you please advise if this is something incorrectly configured on our side or might be a bug in the IPv6 condition check?
This will be fixed in the next release. The change can be applied to /usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/network.py by adding the strip_port function and modifying the get_remote_addr function.
def strip_port(hostport):
colon = hostport.find(':')
if colon == -1:
return hostport
if ']' in hostport:
i = hostport.find(']')
if i != -1:
return hostport[:i].lstrip('[')
return hostport[:colon]
def get_remote_addr():
if settings.app.reverse_proxy:
forward_ip = flask.request.headers.get('PR-Forwarded-Header')
if forward_ip:
return strip_port(forward_ip.split(',')[-1].strip())
forward_ip = flask.request.headers.get('PR-Forwarded-For')
if forward_ip:
return strip_port(forward_ip)
return strip_port(flask.request.remote_addr)
Thank you for your reply and taking this up in the next release.
Something perhaps to consider with this change is that currently all the journal logs contain the IP:PORT in the User’s Audit log visible from Pritunl UI and in the Journal as well:
