Wireguard Go (Go) Vulnerabilities
Even on the latest pritunl client version, Qualys vulnerability scanner is showing a lot of vulnerabilities related to Lib Go (Go) in the wireguard. Could you update the Wireguard or add an option to select if we want or not the instalation of wireguard?
Theres a plan to fix these vulnerabilities?
Those are from library imports that are packaged with the Go code that have reported CVEs. None of the vulnerable components of those libraries are used. This will be updated in the next release but with the significant increase in reported CVEs there is almost always at least one library that has a CVE in one or more of the Pritunl codebases. These would only impact the software if the vulnerable components are used.
