Hello. I’m trying to set up the following architecture: I’m using a load balancer in a public subnet with a certificate. My DNS is pointing to it. The Pritunl server is located in a private subnet, so it has no public IP. I set the Public Address as my DNS name. I also set the same Sync Address in the advanced host section. Pritunl settings are configured as follows:
sudo pritunl set app.reverse_proxy truesudo pritunl set app.redirect_server falsesudo pritunl set app.server_ssl falsesudo pritunl set app.server_port 80
I am able to successfully connect with OpenVPN, but WireGuard fails with a “Handshake timeout” on my server. In the logs, I see only that the user authenticated successfully but then disconnected without any clear errors. To be more specific, on the load balancer I have 3 listeners:
- HTTPS on port 443 pointing to HTTP port 80 on the Pritunl server
- TCP on port 1111 pointing to TCP port 1111 on Pritunl (for OpenVPN)
- UDP on port 2222 pointing to UDP port 2222 on Pritunl (for WireGuard)
Can someone point me in the right direction?
