Yubikey not working any more
We are on v1.32.4469.94 from unstable and Yubikey doesn’t work.
We get to the screen “please insert YubiKey” but when inserted it is not recognised and the key doesn’t blink
The key works on the yubikey test site
Thanks
The Pritunl VPN uses OTP not WebAuthn, this doesn’t prompt the device or cause the light to blink. It should be pressed and this will fill the input with the OTP code. The Yubico OTP Test can verify is this is working. For Pritunl Zero and Pritunl Cloud these do use WebAuthn and should prompt for the key.
