Hey guys ![]()
I have been some trouble with my Pritunl VPN connection lately, and it’s driving me a bit nuts! The connection keeps dropping and then takes forever to reconnect. I’ve tried the usual stuff, restarting the server and my device, but no luck.
Here’s a breakdown of the situation:
- Issue Description: My VPN connection frequently drops and takes a long time to reconnect. I’ve tried restarting the Pritunl server and my local device, but the problem persists.
- Configuration Details: I’m using Pritunl version 1.32.0 on a Ubuntu 22.04 server. My client is running on Windows 11 with the latest Pritunl client version.
- Logs and Error Messages: The logs indicate occasional timeout errors and failed attempts to establish a connection.
[2024-07-22 15:30:12] ERROR: Connection timed out.
[2024-07-22 15:30:45] ERROR: Failed to establish connection after multiple attempts.
I also check this:
https://forum.pritunl.com/t/server-not-accessable-when-its-connect-to-pritunlsalesforce-dev But I have not found any solution.
Thanks a bunch for your help!
Respected community member ![]()
